Results 1 to 9 of 9
    Dec 2011
    ms
    heat pump problems
    i have a florida heat pump drops low voltage when the blower comes on the lights on the board drops out but th
    e transformer still putting out 26 volts.
    Sep 2012
    Could use more info. Or pics. Not alot to go on with this.
    petaluma,ca
    if the transformer is set at 230 and power is 208, you might need to change the setup
    Jan 2010
    Heat Pump Belt
    Bad board??!!
    Nov 2007
    Mississippi
    Quote Originally Posted by trai View Post
    Where are you measuring "low voltage drop out" if transformer still putting out 26 volts?
    Dec 2011
    ms
    at the control board
    Sep 2012
    Does the unit have more than one transformer?
    Nov 2007
    Mississippi
    Quote Originally Posted by ARTICHILL View Post
    Bad board??!!
    I agree
    Indiana
    Ditto
