Results 1 to 9 of 9
Thread: Small 1/5 hp hermetic compressor
10-17-2012, 08:05 PM #1
Hi, Anybody ever come across a new compressor with 1/4 inch discharge port acting and running as a suction port, condensor cold and evaporator warm, this is a single phase, 115 volt small 1/5 hp hermetic compressor with r22 as refrigerant, pressures are 40 psig at ll drier and 60 psig on comp. suction port out the top, disharge is 1/4 inch and suction is 3/8 inch. is this a factory regect, never seen this before. tecumseh comp..
Never Assume Anything
10-17-2012, 08:14 PM #2
You sure it's piped correctly? There are plenty of pumps out there with a 1/4 or 5/16 discharge line, 3/8 suction line and 1/4 suction tap.
Local 597 Service Fitter
Metal Trade Journeyman
PAY ME NOW OR PAY ME LATER
It was working when I left...
WWFD
10-17-2012, 08:28 PM #3
Hi, so what your saying is that on this compressor the 1/4 inch is the suction and the 3/8 is the discharge. i have never seen this before, i was trained that the smaller tube is going to be discharge line. thanks
10-17-2012, 10:33 PM #4
No. There are 3 tubes on most small tin cans. a discharge which is either 1/4 or 5/16. There are 2 suction tubes. one is 3/8 and the other is 1/4. The 3/8 is for the suction line and the 1/4 is to put a schrader tap on.
WWFD
10-17-2012, 10:54 PM #5
10-18-2012, 06:15 AM #6
I took measurment with caliper there is 1 tube that comes off the top part of the compressor and goes straight up which is 5/16 and put my schrader for suction press., and there are 2 tubes that come out lower on comp. 1 is 5/16 or .3125 the other is .250 and which data says that is discharge but i am getting suction on this 1/4 inch tube, comp. goin back
10-18-2012, 08:25 AM #7
- Jan 2005
- texas
- 110
Don,t forget to use a biflow drier in your new heatpump.
10-18-2012, 09:35 AM #8
What's the compressor model number?
Also, if you have the Bill of Material (BOM) number, you can ID the stub tube connections by entering it in this little program: Compressor Housing Drawing App
10-18-2012, 12:43 PM #9
- Sep 2008
- 501
On most of the Tecumseh fractional hermetics I've seen the Suction line is highest and largest. The discharge is next to the process and just below. YMMV.
Tecumseh has an excellent service handbook, pm me your email if you would like a copy.
