Results 1 to 4 of 4
    Nov 2010
    mini split question
    I currently have a Mr. Slim system in my converted garage. The room is 20x11 fully insulated and it has worked great for the past 3 years. I selected a system that could handle a much bigger room and it keeps the room ice cold if i need it to be.
    I'm thinking of building a wall with an open doorway to split the room in half and make it 2 rooms of 10x11. The mini split is located in the back of the room and i'm wondering how well it would cool the front half of the room with a wall installed. If done, the back room where the mini split is would be a workout room and the front room would be a little media room. Just wanted to get some advice and see if I would be okay doing this. I just dont want that front room to be warm while the back freezes.
    Apr 2011
    SE Washington
    well.... you obviously would be blocking airflow by building the wall and relying on simple convection to the new space, it will get some, if the doorway is left open.....
    May 2009
    Cumming, GA
    You will absolutely notice a difference in the air flow and temp on the far side if you construct a wall. What's the model and serial number for the condenser? Some select condensers are able to operate multiple evaporators. If your condenser is applicable; installing another AHU/Evaporator may be an option.
    Quote Originally Posted by Brent Ridley View Post
    or 1 ducted air handler
