Results 14 to 22 of 22
12-11-2012, 09:27 PM #14
I agree silicone looks 300 times better, i hate foil tape
hes talking about the joints between filter base and furnace, and between furnace and coil housing. honestly im wondering about your bubble wrap now , no insulation inside plenum or what?(((PEACE IS THAT BRIEF MOMENT IN HISTORY WHERE EVERYBODY STANDS AROUND RELOADING)))
(((YOU SEE A SIX PACK, I SEE A SUPPORT GROUP)))
12-11-2012, 09:32 PM #15
the gas flex looks good tho
12-12-2012, 07:05 AM #16
- Jan 2011
- 502
12-12-2012, 07:21 PM #17
12-15-2012, 12:48 AM #18
Professional Member*
- Nov 2009
- Kansas City
- 114
If our guys set that unit that close to the wall they would be fired in a second. The lead installer shouldn't of let that happen. If he doesn't get fired I would definetly make him pump the unit down and reinstall it away from themwall so it can be serviced. Have him do it of course on his own time without pay....
01-04-2013, 11:47 PM #19
- Jun 2011
- New Braunfels, TX
- 47
Are you having massive coil problems with the 410a coils?
The company I worked for used to install the most 17-18 SEER 2 Speed HP's in south central Texas, but our failure rate is nearly 80%!
01-05-2013, 12:08 AM #20
whats the point off all the foil tape.... it looks like hell.... a proper sheet metal joint requires zero foil tape..... i don't get it.....
01-06-2013, 12:43 PM #21
- Nov 2008
- DFW,TX
- 1,891
01-06-2013, 01:27 PM #22
Looks good brother.
Was that transite flue pipe in the first picture? I've only seen that stuff once, seems like you see it all the time!"Better tell the sandman to stay away, because we're gonna be workin on this one all night."
"Just get it done son."
Dad adjusted
lked together as it is put together.
