Results 14 to 22 of 22
    Nov 2011
    GA
    Quote Originally Posted by heresjohnnyb View Post
    the last time i saw that much metal tape on equipment,i took all of it out of the installers truck and gave him a caulk gun with some high temp CLEAR silicone. drives me crazy seeing all that tape. it should be caulked together as it is put together.
    I agree silicone looks 300 times better, i hate foil tape
    Quote Originally Posted by JKopp View Post
    That is bubble wrap over sheet metal if your talking next to the ceiling.
    hes talking about the joints between filter base and furnace, and between furnace and coil housing. honestly im wondering about your bubble wrap now , no insulation inside plenum or what?
    (((PEACE IS THAT BRIEF MOMENT IN HISTORY WHERE EVERYBODY STANDS AROUND RELOADING)))
    Nov 2011
    GA
    the gas flex looks good tho
    Jan 2011
    Quote Originally Posted by david912 View Post
    And foam tape looks better than slipcon.....
    Nov 2011
    GA
    Quote Originally Posted by jimmyed View Post
    Foam tape does look good
    Nov 2009
    Kansas City
    If our guys set that unit that close to the wall they would be fired in a second. The lead installer shouldn't of let that happen. If he doesn't get fired I would definetly make him pump the unit down and reinstall it away from themwall so it can be serviced. Have him do it of course on his own time without pay....
    Jun 2011
    New Braunfels, TX
    Are you having massive coil problems with the 410a coils?
    The company I worked for used to install the most 17-18 SEER 2 Speed HP's in south central Texas, but our failure rate is nearly 80%!
    Apr 2012
    winnipeg
    whats the point off all the foil tape.... it looks like hell.... a proper sheet metal joint requires zero foil tape..... i don't get it.....
    Nov 2008
    DFW,TX
    I dont agree its preference, we do the tape, sometimes caulk and tape depending on acess..it personal preference..
    Cincinnati, Oh
    Looks good brother.
    Was that transite flue pipe in the first picture? I've only seen that stuff once, seems like you see it all the time!
    "Just get it done son."
    Dad adjusted
