Results 1 to 13 of 21
    In a machine room
    Personal CO monitor
    Anyone else carry one? I just got the new CO Angel. It has super fast response. Totally water and shockproof.
    Arizona
    We use the SENSIT P100. I have not seen the CO Angel before, where did you get it?
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    In a machine room
    Quote Originally Posted by jimj View Post
    From NCI. It is the model 5000.
    Worry is a really gross misuse of one's imagination. -- PHM
    Arizona
    S.E. Pa
    Chuck, I didn't see the sensor life in the specs. Any idea as some personal CO monitors are only 2 yrs and non-replaceable.
    Otherwise, looks like a great value and fantastic must-have for every tech. My old Scott Bacharach unit is dying and I need a new one. However, I was thinking about a 4 in one: CO, O2, LEL, H2S
    May 2012
    Upper Michigan
    What's something like that cost?
    Arizona
    Go here.
    http://www.nationalcomfortinstitute....cfm?Cat=Carbon Monoxide, Combustion, and Safety Tools
    May 2012
    Upper Michigan
    Thanks didn't make the connection when chuck said NCI
    In a machine room
    http://www.sensorcon.com/carbon-monoxide-detectors/
    This looks like the same thing. Only this one has a low alert of 35 ppm and a high alert of 200!
    Rochester NY
    In a machine room
    Quote Originally Posted by hearthman View Post
    I'm not sure on the life. I know the sensor can be calibrated with 50 ppm test gas. I would hope this would extend its life.
    Avon Lake, Ohio
    It is waterproof but I found out in Chicago it is not booze proof. Put it in a glass of wine and it got drunk and has been slightly hung over ever since.
    captain CO
    In a machine room
    Quote Originally Posted by Jim Davis View Post
    In wine??
    Why am I not surprised?
    Jim, do you know what kind of sensor life we can expect?
