Results 1 to 6 of 6
    Oct 2012
    Another Oil to Gas Burner Conversion
    I have a two year Buderus 155 boiler with a Riello burner, and as seems to be the new fad, I am looking to change the oil burner to gas, specifically a Riello Series 40 FS head. I have gotten a lot of miss-information from HVAC guys with limited experience with the boiler, the Riello head, converting or all of the above. I know the boiler is a high efficiency unit, relatively new, used only for heat as I have a gas fired hot water unit, and had the chimney lined at the time. I am looking to find someone familiar with what I am intending to do, the equipment that I have and give me the straight story on the pros/cons of the conversion.
    Any takers?
    Made this into its own thread. You are not permitted to post in other peoples threads in the AOP forums, please read our site rules, thank you.
    In a boiler room
    I can do it......
    You didn't say where you are from.......
    Oct 2012
    I can do it......
    L.I., NY
    In a boiler room
    Check the HVAC-Talk contractor map, you should be able to find someone that can help you with that.
    Oct 2012
    Thanx for the heads up, found two contractors and have sent emails, I assume that there are others and I hope some reach out to me about the work.
