Results 1 to 11 of 11
10-16-2012, 12:09 PM #1
- Oct 2008
- Fullerton
- 705
Fieldpiece DDSM1 Pressure Switch Tester
Check out the video for the DDSM1 Pressure Switch Tester.
11-22-2012, 02:19 PM #2
I have one and works great! not a tool you need every day but nice to have.
11-22-2012, 02:32 PM #3
Why is this necessary when the same can be accomplished with a manometer, multimeter and your fingers squeezing the tube (provided you really cared at which point the switch was making or breaking after determining it was bad).
I think I've had one genuine bad pressure switch in an entire heating season.
11-22-2012, 03:14 PM #4
- Aug 2012
- NE wisconsin
- 178
They are very usefull in setting universal pressure switches.
11-22-2012, 03:21 PM #5
11-22-2012, 04:03 PM #6
It works really good to check full modulating furnaces that set there gas pressures off the pressure switches. Pressure differential is very imported with this type of furnace.
11-22-2012, 05:20 PM #7
As I understand it, this is the draft rite tool now owned by Field Piece. The draft rite is not something I need often, but it sure is good at what it does. I use it to test pressure switches and set universal pressure switches for accurately replacing the old one. And I have used it in one case to find out that the hack installers reduced 3" PVC to 2" at the termination point of a condensing furnace which caused furnace shut downs.
11-22-2012, 05:21 PM #8
11-22-2012, 05:30 PM #9
11-22-2012, 09:42 PM #10
- Aug 2006
- Colorado
- 236
I was thinking about this tool the other day when I had to adjust two brand new Reznor pressure switches. They were rated for 1.0" but started flapping the gas valve at 1.2" I had to use the manometer tee and the 'pinch' method. How much does that tool go for?
11-22-2012, 09:46 PM #11
