Results 27 to 39 of 97
10-17-2012, 11:46 AM #27
Professional Member*
- Oct 2012
- Toronto, Ontario
- 67
if its 80 inside ur pressure should be up close to 80 so either a) ur giving me wrong information or b) if it was 75 then 68 could be reasonable, so which one was it so no need to get defensive,
10-17-2012, 11:47 AM #28
no, good split, good to go
10-17-2012, 11:51 AM #29
10-17-2012, 11:55 AM #30
- Oct 2012
- Toronto, Ontario
- 67
its sounds like its low on freon just a little bit, and it is a rheem another good reason to condemn
10-17-2012, 12:00 PM #31
Not being defensive, just trying to understand why the service tech would say the pressures were good and you're saying they're not good. As I said, it was 80* inside before he touched the unit. By the time I got inside to close the windows it had started cooling already. May even have been down to 77 or so at that point, I don't know. I do know it hit the 75* setpoint soon after he left and has been working ever since.
10-17-2012, 12:10 PM #32
10-17-2012, 12:26 PM #33
- Oct 2012
- Toronto, Ontario
- 67
10-17-2012, 12:41 PM #34
10-17-2012, 12:52 PM #35
10-17-2012, 12:56 PM #36
- Oct 2012
- Toronto, Ontario
- 67
10-17-2012, 01:01 PM #37
I'm not sure my paying an independent contractor to condemn the unit would result in enough of a cash-out settlement from the HWC. I tried that when I decided to replace the entire Federal Pacific Electric breaker box when the breaker for the water heater wouldn't stop tripping. Yes, the entire system was "condemned" as a fire hazard by the contractor, but because the other breakers were "still working" the HWC would only reimburse me for the "cost to repair/replace the failed component", which was the one circuit breaker. So.... there'd have to be a significantly expensive "failed component" for them to cash-out the HP based on another contractor's diagnosis. And I'm not sure paying a contractor enough to "fudge" a compressor failure would be a good idea.
10-17-2012, 01:08 PM #38
I didn't say anything about charging. I said assessing charge. Do you understand the difference? You saying that the unit is 'a little low' based on nothing but suction pressure and indoor dry bulb is wrong. The ID DB is 80 so the suction pressure should be 80? That is a hillbilly method of assessing charge. Why didn't you just ask if the suction line was beer can cold? The fact that you would trash talk a brand on AOP is also wrong. The fact that you are posting is AOP is wrong. You are 360* of wrong. Any other stupid questions?
10-17-2012, 01:11 PM #39
- Oct 2012
- Toronto, Ontario
- 67
sure what kind of sandwich is that
