Results 1 to 12 of 12
    Oct 2006
    Hmm
    coleman 75k btu fan continuously running. Horrizontal system . Old system standing pilot. fan limit switch haas been installed.
    SW FL
    Originally posted by available
    coleman 75k btu fan continuously running. Horrizontal system . Old system standing pilot. fan limit switch has been installed.
    Is there a question in this comment?
    Designer Dan
    Jan 2006
    Dayton, Ohio [USA]
    is the fan switch on the thermostat [if it has one] set to auto or on?
    Oct 2006
    Hmm
    the question is, does another fan limit switch need to be installed or does the points need to be reset to another setting. thanks
    SE Michigan
    Call for a service appointment and have it inspected.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Jan 2006
    Dayton, Ohio [USA]
    you may want to find out if the fan switch has its own manual or automatic setting. this can be done by looking at the furnace manual or the fact sheet if the technician whom installed the switch left it for you. like you said, it may just need to be adjusted. try turning the heat on, let it run for 15 minutes or so, then turn the heat off. if this doesnt help, you should have the switch reset. i would not reccomend you do this yourself.
    Florida
    This is the best advise. You've already replaced a limit which didn't solve your problem. Gas furnaces can be deadly...have it checked.
    May 2003
    Dixie
    listen to the man
    Jan 2003
    Kentucky
    preach it brother man..
    Oct 2006
    Hmm
    Maybe I did'nt make myself clear this system is so old that the coleman dealer did'nt even have a trouble shooting chart to work with i was just wondering if any of U guys in the field had run into a simular situation that maybe U could give me some info as to where I could get one either on line or from previous experience or am I in the wrong category to get insight from a fella tech. Who I may be a novice in comparison to some of U guys.
    South Central Kansas
    Coleman buys back their best of the oldies and put it on display, try contacting coleman, that old unit may be worth some real money!
    Sep 2006
    Your fan relay contacts could be stuck closed(welded,pitted etc.), your thermostat defective or wired improperly.
