    Silver Creek, Ny
    Tankless water heaters and flo-check valves
    I just installed my 1st tankless hot water heater this weekend and it gave me an idea about flo-check valves.
    We are still having an issue with getting hot water to remote areas like the bathroom faucet that for some reason takes over 3 min to heat up, yet the bath faucet 4 ft closer to the heater takes only about 20 sec.
    So I was thinking about maybe putting in flo-check valves in strategic locations like near the bathrooms and just outside of the heater outlet....to try to trap in some of that hot water.
    As it sits right now, the way I see, it, as soon as you turn the faucet off...the boiler shuts down and cold water fills back in to the hot water piping, leaving the hot water pipes cold for the next hot water draw.
    Wouldn't flo-check valves solve this problem????
    Perfect Practice Makes Perfect
    Dec 2008
    Buffalo NY
    I would use a recirculating pump for this situation. You can set for a certain temp and the time you want it hot. Then you have hot water all the time.
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    willowick ,oh
    I agree a circulation loop will do the trick correctly. Buuuuut almost all manufacturers will adjust warranties according. I deal Rinnai and naviens. For residential it drops warranty from a 25 year heat exchanger to a 5 year. It shows a schematic in all install piping diagrams. Pretty simple
    May 2012
    Upper Michigan
    Yep recirc pump
    Urbandale IA. USA
    I bought one of these Taco pumps, put it under the sink in the upstairs bathroom, and it dropped my water bill by $10 a month.
    I really like it, although it is pricy.
    http://www.build.com/taco-008-dm-pk-...FYs7MgodvQ0AwQ
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
