Results 14 to 26 of 30
    Jul 2011
    NYC
    should the blue or red nylog be used? im having the same issue the ak900 just arrived and my high side is leaking at the manifold connection. i also do refrigeration work which includes cfc hcfc and hfc i dont know if choosing one nylog over the other makes a difference regarding system contamination because they are made with different refrigeration oils.and i really dont want to mess up my new shiny toy
    Dec 2008
    Buffalo NY
    Quote Originally Posted by nyc_badboy View Post
    I used the red. It is so small of an amount it really does not matter.
    Sent from my iPad using Tapatalk HD
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    It don't matter which one you use. Be the same as pissing in the Atlantic Ocean as to making any difference.
    Jul 2011
    NYC
    lol at refferman and thank you for your reply both of u i used the red one and its not leaking at the joint anymore but now i have a new problem. since i just got them like a day ago i was testing them today i put nitro in my middle port with the low side handle at off closed possition. my low side started increasing at .25 psig increments all the way to 50 -60 psig and it kept going while the high side stays stable at 0 psig. this leads me to believe there is an internal leak at the manifold. then whith pressure in middle port i opened the low side handle and the gauge correctly shows 150 psig of nitro. i close the low side valve and now it starts going down at .50 psig increments . i dont know what to say and i dont know if anyone else has that issue. i contacted digicool and left a message to brenda hopefully they call me back because i hagte having to trouble shoot new toys that i was anxciously waiting for. it was a tight choice for me between the testo or digicool and i picked digicool due to the reliability and accuracy. i hope they dont dissapoint me. ill have to wait till brenda or doug get back to me i guess.
    Dec 2011
    Northeast PA
    mine leaked a bit with nothing on the threads when pressure tested with nitro. Used a bit of teflon tape and haven't had an issue since.
    What most are not saying is what manifold they are connecting it to.
    Mine is connected to the supplied manifold.
    Jul 2011
    NYC
    I'm using the stock manifold it came with and I'm having internal leak the leak that I was having connecting to it was alleviated using red nylog I left a second message to digicool and no reply yet...... Most of the people swear by digicool customer service I guess I'll just wait for a reply ad keep u guys updated .... Does anyone have Doug's direct cell by any chance ? ;( I gotto to get this resolved I have 3 refrigeration calls today and I would love to put the digi"s to use
    Jul 2012
    Athens, GA.
    Sounds like the lowside valve needs to be checked. Mine loosend up and was venting out of the seal for some unknown reason. I pulled the knob and put a wrench on it and everything is kosher since.
    JASON sent this from his DUMB-PHONE
    Jul 2012
    Athens, GA.
    If you cant figure it out. Just throw your old manifold on with the adaptors that came with it until you sort it out.
    Jul 2011
    NYC
    Well I don't want to sound like a nagger but when we buy a product that everybody praises to be top notch quality etc etc why do we have to sit here and change manifolds to try and troubleshoot a brand new product .... That kinda annoys me .... I left 2 voicemails and still no answer lets see the world class customer service at work cause as of right now all I'm getting is a voicemail...
    Dec 2011
    Northeast PA
    the problem that I found lies in the connection type. One is set up for a flare fitting while the other isn't
    Jul 2012
    Athens, GA.
    So your not going to try troubleshooting it yourself until doug calls you back?
    Okie dokie smokey. Carry on with your nagging. :beer:
    Jul 2009
    Columbia, MD
    I thought we are mechanics here.. look at the side port. there is a spot to put a allen key. find the correct allen key and snug it up.
    that should fix your problem. if that dont work pop off the blue knob and tighten the ball valve underneath.
    i had the same problem with mine when i got them. i did not need to call anyone to fix it.
    Jul 2011
    NYC
    To the last posts that were hasty to jump on the gun ... No I'm not going to try to fix sthing that is brand new so I can break it and wait for a new one to be shipped in...regarding Doug he did call me back and he's awsome he was spot on and everything is well ... It was the allen screw on the side but I was still leaking so he didn't suggest nylog he told me leak lock between manifold and screw not manifold and digital head so I followed manufacturers recommendations and did so .... It works like a charm now .... To everyone else thank u for your replies this forum is awsome because it has knowledgeable and helpful people like u ... Thank u
