Results 14 to 25 of 25
Thread: Goodman Res. furnace help
10-14-2012, 05:14 PM #14“I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
No Guns…No Freedom…Know Guns…Know Freedom.
10-14-2012, 06:12 PM #15
- Mar 2009
- 31
and your point is?
10-14-2012, 06:38 PM #16“I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
10-14-2012, 09:36 PM #17
Sorry I am late getting in. 120v supplied to the board is through the molex connector. I have 24v at R. I have 120v at eac and motor is fine. No power to 5 pin molex when w is powered. I wired inducer to eac and it ran fine. Powered w while inducer running and would not advance to ignition or give fault code.
There is no bad beer, some just taste better than others.
10-14-2012, 09:40 PM #18
There is no way to wire board wrong. Only spade connections are for the transformer.
10-14-2012, 10:18 PM #19
So did we confirm if the inducer motor itself is still good?
Had a Lennox inducer which fried the IDM relay on the board due to short to ground. The control still acted fine until it didn't see the pressure switch close.
10-14-2012, 11:43 PM #20
Never mind.
10-15-2012, 03:12 PM #21
New Guest
- Mar 2011
- 5
Is there water in the trap?
I've seen units not fire because of this, don't recall but I think the inducer at least kicked on.
10-15-2012, 07:51 PM #22
While I appreciate your input, you might want to read all the posts. Water in the trap ?? I hope so. A blocked trap will prevent ignition, but only after inducer starts. Any other thoughts ??
10-15-2012, 08:27 PM #23
- Mar 2011
- Zeeland, MI
- 21
help me understand you have the new board in it and it doesn't flash any codes? does the blower run at all with or without the fan switch "on"? and you disconnected the t-stat wire and jumped out r to w1, with 24v from r to c?
10-15-2012, 08:43 PM #24
Well man if you have power to the board, you have 24v between C and W, and you dont have power coming out of the board, it sounds like the board to me. You bypassed the board and the inducer is operating properly, if you dont have power coming out of the board to the molex plug with a call for heat, i would say its the new board. although it is wierd the old board wouldnt bring the inducer on either, unless the is some kind of problem with those model control boards. Ive had parts come right out of the supply house faulty, its sucks when you get a sweat txv pumping down right out of the box and being careful to keep the valve cool when soldering
(((PEACE IS THAT BRIEF MOMENT IN HISTORY WHERE EVERYBODY STANDS AROUND RELOADING)))
(((YOU SEE A SIX PACK, I SEE A SUPPORT GROUP)))
10-15-2012, 09:06 PM #25
- Jun 2009
- Ontario, Canada
- 846
ok tips of the trade: bring a cheater chord for 120v. you could test your blower (PSC only) and inducer. inducer got 120v, check your capacitor. cap OK then bring the cheater chord and test your inducer. that's the long way around. the short way is oif you got no power to the inducer then the board is pooched. if you do get power then it's the inducer. it's simple. don't think about it too much. the board is just an integrated time delay and relays, but it's ONE component. there's nothing you could change on it legally. if the board says no go the rest is no go. replace the board.
Parts Changer Extraordinaire
Have tools and gauges. Will travel.
