Results 1 to 13 of 25
    Aug 2011
    Ontario
    Goodman Res. furnace help
    Working on a Goodman Model # GMV90905 DXA. Powered up unit, called for heat and board immediately gave a 3 flash code. ( Low fire p.s. stuck open ) inducer never started switch should be open ?? Took off all stat wires and jumped w1 & r powered up again and got different code. 4 ( open H.L.) again inducer never started. All 5 limits are closed. No power out of board to inducer. Ordered new board and installed. Now I get nothing. No fault code. Have 24 v at r & w
    Inducer motor and ignitor check out o.k.
    Am I missing something or did I get a new bum board.
    There is no bad beer, some just taste better than others.
    Calgary, Alberta
    Check your jack plug into the board.
    Is 120v polarity correct and you have 24v from the transformer?
    Aug 2011
    Ontario
    All 3 jack plugs are tight and yes I have 24v from tx. polarity is correct.
    Calgary, Alberta
    Quote Originally Posted by talktowags View Post
    It's not the plug itself, are the wires securely inserted into plug?
    It's very rare to see a DOA board, in my experience.
    Is it possible you have something shorting out or a wire worn through?
    Your meter should be able to sort this out, it will just take patience.
    I'd have another transformer ready, just in case.
    Aug 2011
    Ontario
    I am getting no power to the plug from the board. I put old board back in and I got my fault codes again. New board nothing. Will go at it again on Monday. Thanks for your input.
    Mar 2012
    New Hampshire
    Quote Originally Posted by syndicated View Post
    Put a fuse inline, save the transformer.
    "I don't know why it be like it is, but it do"
    Oct 2012
    Corryton,TN
    Make sure the neutral hasn't come loos e in the disconnect
    May 2011
    Southern Indiana
    It sounds like the original problem was your circuit board. I ran into a bunch of Goodman units, two heating seasons ago, that were doing the same thing. Make sure you have your new board wired correctly. You may have sent 120v through the 24v side somehow and fried it.
    Nov 2007
    Mississippi
    Quote Originally Posted by rivervalleytech View Post
    Second that. Check your wiring.
    Houston,Tx.
    I believe most anything is possible, but I just need a little explanation on how this could happen, when the power to most boards is feed to the board through a fitted molex connector.
    Thanks!
    “I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
    The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
    No Guns…No Freedom…Know Guns…Know Freedom.
    Dec 2011
    Twin Cities Minnesota
    You said the Inducer never ran..,jump to see if motor fried!
    Mar 2009
    see if you got power going to ventor motor
    Houston,Tx.
    Quote Originally Posted by Cosmicmuffin View Post
    Here.
