Results 14 to 26 of 32
10-13-2012, 08:17 PM #14
10-14-2012, 03:14 PM #15
Here's another that I've used with some success, particularly with fan shaft/hub assemblies.
Heat it up cherry red. Take a candle and smear it at the junction of the two parts.
Some of the wax will smoke off, but some will melt and flow between the parts, creating a lubricating film.
10-14-2012, 03:25 PM #16
- Jan 2007
- Monroe, MI
- 16
For broken bolts that are not too rusted in I like to use a left twist drill bit to drill them out. Many times just the drilling force will be enough to back to broken portion out. Otherwise heat and patience normally work.
10-14-2012, 03:27 PM #17If a day goes by and you have learned nothing, I hope you got a lot of sleep.
10-14-2012, 03:33 PM #18
10-14-2012, 05:12 PM #19
10-15-2012, 12:15 AM #20
In automotive repair, and later in boiler and pump repairs, I have used the candle wax trick many times with success. It gets sucked into the threads like solder.
Guys, if you heat the tapping instead of the bolt you will get better results. When you heat something with a hole in it the hole gets bigger. If you heat the bolt more than the tapped piece, it gets tighter until the temps equalize.
10-15-2012, 12:23 AM #21
As for extractors, I have tried a lot of different ones. So far these are the best I have used. http://buy1.snapon.com/catalog/item....mp;dir=catalog
10-15-2012, 12:36 AM #22
Broken link
Truth is still truth, even if no one believes it. A lie is still a lie, even if everyone believes it.
"It's called the american dream because you have to be asleep to believe it" -George Carlin
"A nation of sheep begets a government of wolves" -Edward R. Murrow
"I have problems just like you. One time, my dancing horse almost fell into my car elevator" -Mitt Romney
Buy american made goods & support locally owned businesses!
10-15-2012, 07:19 AM #23
- Nov 2011
- Charleston, Wv.
- 789
gotta shock them too.....a few good swift whacks with a hammer will sometimes break the rust.
10-15-2012, 08:52 AM #24
10-15-2012, 08:53 AM #25
10-15-2012, 10:25 AM #26
Left handed drill bits are must, X2 on Snap on extraction products (been through many Snap on works and lasts) and X3 or 4 on the tranny fluid.
the candle wax trick works, I also never done my self but a friend in the marine industry uses ''Mint'' on aluminum.It's hard to stop a Trane. but I have made one helluva living keeping them going.
