Results 14 to 26 of 32
    Jul 2012
    Richland, WA
    Quote Originally Posted by Tech Rob View Post
    Any particular brand or kind of transmission fluid??? I think I'm going to try this out.
    I just bought the cheapest and it worked. I don't think it really matters.
    Here's another that I've used with some success, particularly with fan shaft/hub assemblies.
    Heat it up cherry red. Take a candle and smear it at the junction of the two parts.
    Some of the wax will smoke off, but some will melt and flow between the parts, creating a lubricating film.
    Monroe, MI
    For broken bolts that are not too rusted in I like to use a left twist drill bit to drill them out. Many times just the drilling force will be enough to back to broken portion out. Otherwise heat and patience normally work.
    Mar 2010
    Morgan Hill Ca.
    That is a trick that I believe came from the military. I believe I read it in a field handbook having to do with tank tracks or something (my granddad was a Screaming Eagle Paratrooper in WWII, I was never fortunate enough to be in the armed forces).
    GT
    Quote Originally Posted by GT Jets View Post
    GT
    I never knew where it came from.
    I believe that I read it online somewhere.
    Mar 2009
    Mid-Mo
    Wow, interesting. Gonna have to remember all of these for the next time!
    In a boiler room
    In automotive repair, and later in boiler and pump repairs, I have used the candle wax trick many times with success. It gets sucked into the threads like solder.
    Guys, if you heat the tapping instead of the bolt you will get better results. When you heat something with a hole in it the hole gets bigger. If you heat the bolt more than the tapped piece, it gets tighter until the temps equalize.
    In a boiler room
    As for extractors, I have tried a lot of different ones. So far these are the best I have used. http://buy1.snapon.com/catalog/item....mp;dir=catalog
    Home of the newly wed and the nearly dead
    Broken link
    Truth is still truth, even if no one believes it. A lie is still a lie, even if everyone believes it.
    "It's called the american dream because you have to be asleep to believe it" -George Carlin
    "A nation of sheep begets a government of wolves" -Edward R. Murrow
    "I have problems just like you. One time, my dancing horse almost fell into my car elevator" -Mitt Romney
    Buy american made goods & support locally owned businesses!
    Nov 2011
    Charleston, Wv.
    gotta shock them too.....a few good swift whacks with a hammer will sometimes break the rust.
    In a boiler room
    Broken link
    Try this.
    http://buy1.snapon.com/catalog/item....re&dir=catalog
    In a boiler room
    Quote Originally Posted by 71CHOPS View Post
    Yes. A good impact wrench, one that you can feather the trigger to just get a steady slow hammer action works wonders too.
    Dec 2010
    Down by the river
    Left handed drill bits are must, X2 on Snap on extraction products (been through many Snap on works and lasts) and X3 or 4 on the tranny fluid.
    the candle wax trick works, I also never done my self but a friend in the marine industry uses ''Mint'' on aluminum.
    It's hard to stop a Trane. but I have made one helluva living keeping them going.
