Page 1 of 5 12345 LastLast
Results 1 to 13 of 63
    Sep 2012
    Need help with final decision
    First, thanks to everyone who has helped me get to this point. Your knowledge and assistance has been extremely helpful!
    I have narrowed it down to Trane or Bryant and would appreciate your thoughts on the 2 systems.
    My hose is as follows:
    1,500 s/f single-story ranch over a crawlspace.
    Mid Missouri
    3 ton condenser - 9 SEER
    75,000 btu gas furnace
    Trane contractor suggested the following:
    XR15 2-ton single stage condenser - 16 SEER
    XV95 2-stage, variable speed gas furnace
    "matching coil"
    TCONT thermostat
    Bryant contractor suggested the following:
    127A 3-ton two stage condenser - 16.5 SEER
    96T 2-stage, variable speed gas furnace
    CNPV*3717A** indoor coil
    T6 Thermostat
    As you can see the biggest difference I see if the condenser unit. Trane being 2 ton single stage and Bryant being 3 ton two stage. The Bryant contractor said a 3 ton two stage would serve me much better than a 2 ton single stage.....
    As far as I know, they both did pretty much the same load calculations.
    Any thoughts would be more than appreciated!
    If a 2 ton unit can cool the joint, buying a 3 ton 2 stage is like buying a very expensive single stage. Might as well not let it run on high. Low is around 25,000 BTUs and should handle it assuming 2 ton is the load.
    X2
    Sep 2012
    I did want to add that of the 4 contractor visits, only Trane suggested a 2 ton. The others suggested a 2.5 ton. When I told them I wanted to go to a 2 stage, that is why he bumped it up to 3 ton because the 127A doesn't come in 1/2 ton increments.
    Also, the price is almost exactly the same between the Trane and Bryant.
    I would get a 2 Ton 2 stage if the load is 2 tons, you can always fix the house to match a smaller unit if it won't keep up. The temp that is used to do a load calc is a temp that the area only gets to about 10% of the summer so it would run in low stage saving you $ the other 90% of the time.
    Sep 2012
    So you are suggesting I ask the Bryant guy to install a 2 ton instead of a 3 ton? Just asking here, but why would 3 of the 4 say 2.5 tons if they all did similar load calculations?
    The input numbers are left to the person inputting's discretion, most contractors are sooooo scared of under sizing that they will fudge the inputs which results in a larger size.
    Jun 2001
    +1 !!
    Jul 2012
    Western KY
    If the load calc came to 2.5, assuming that's about where your at, a 2 will get you there most of the time. MOST of the time. So it's really up to you. Are you gonna be ok with a 3-5 degree slide on a 95 degree day? What about 2 weeks of 100+? That's where you come into the equation. If 2.5 is the load 3 will work without the slide on a max design day but you will give up some efficiency. A 2 ton you will get max efficiency, and better comfort most of the time but. So you have to add your 2 cents now and make the call.
    Sep 2012
    I know the Trane guy was adamant about sticking with a 2 ton unit. I questioned him several times and each time he said he was confident in his load calculations.
    I guess we need to throw away this years heat wave huh? This area gets hot and humid, but we probably average 15 days over 95 degrees during a "normal" summer. So considering the fact that the Trane rep (Who I had a lot of respect for as he was extremely knowledgeable) was adamant about 2 tons, maybe I should listen to what he was preaching and go with the 2 ton.
    SW FL
    Quote Originally Posted by Zomby View Post
    What would someone from Dallas say about " throw away this years heat wave"?
    I truly wonder if one or two years becomes one or two DECADES of HIGHER THAN EXPECTED summer temperatures?
    I.E. ... the area of 20+ days > 96F' could be enlarged
    I guess I should review the latest temperature trend in Chicago ?!!
    It's best to read and re-read the recommendations of Bald Loonie ( post #2)
    THERE will ALWAYS be a DILEMNA out there as so well expressed by TommyKnocker in post #8.
    I trust MY Calculations AFTER I review them and have assessed their inaccuracies, if any.
    ... "The Art" of equipment selection.
    Trying to maintain < 75'F inside temperature is a great benefit
    to the local utility. Equipment performance is simply not as efficient. !..!!.!!!.
    You effectively have been forced to donate an ~extra $100 / month to your favorite charity.
    I know from your post stating " running from 10 am - 8 pm" that the
    old -jet engine- unit is likely underperforming
    unless you are talking about days
    where it's still > 90'F at 7 pm.
    Designer Dan
    Sep 2012
    So what would your suggestion be from what you have seen me post? 2 ton single stage or 3 tom two stage? I would sure appreciate your opinion!
    Sep 2012
    I mean to say 2 ton/2 stage or 3 ton/2 stage.
    All help appreciated! I have to make a decision before Monday to capitalize of our power companies financing and rebates.
