Results 1 to 2 of 2
    We have a Trane XV90, installed mid-2004. We had to replace the igniter last Oct., after having it a little over a year - it was blowing cool air. Now, it's doing it again - but apparently, only in stage 2. The contractor just left, and told me he turned off stage 2, so it will provide heat - and that he's going to obtain a new circuit board, so he can replace that, probably tomorrow.
    I'm a novice, but I like to learn - especially when it's regarding repairing a relatively new system, for the second time. Based on what I read on threadid=71113, I'm not so confident that a new circuit board is going to fix it. I did show the contractor that thread, but he said it had nothing to do with it - is that why stage 1 is working? What other areas/parts should be checked - what could the culprit be? He thought at one point it might be due to a spider in the pipe leading outside - he cleaned a web out, but that had no effect. (is it really that sensitive?)
    thanks for your help! Cathy
    Cathy,
    if he’s an authorized Trane dealer he should be able to call his local distributor for tech support.
    Licensed to chill
