Results 1 to 11 of 11
    Aug 2008
    3.5 Ton HEIL 14.5 SEER Package Gas
    Removed an Old Snyder General Gas Pack that was installed in 1989. It was in good working Order. The Customer decided not to replace the Condenser Motor on the "Old Thing". Installed a New HEIL 14.5 SEER Gas Pack, New Honeywell PRO5000 T-Stat, New Return Air Grille and Sealed the Duct With Mastic. Sweet Change out.
    Jul 2009
    Columbia, MD
    looks really good.
    May 2011
    Western, KY
    Pretty clean.
    Just a suggestion if you want to do an even better job. Where the condensate is going to drip, dig a hole with a post hole digger, line it with PVC pipe, fill it with loose fill rock, this should be level with the ground at the top, now when the unit drains you don't create a big soggy/muddy/pond area in their yard that gets run through by mowers, attracts wasps, and breeds Mosquitos.
    Oct 2005
    nice and clean
    RTFM!!!
    Jan 2012
    Tallahassee,Fl
    Nice!
    Sep 2012
    Missouri
    Good job!!
    Apr 2012
    winnipeg
    well done...
    Oct 2012
    Nice Install, never been a fan of the brand but looks very sharp!
    Jul 2009
    Columbia, MD
    it comes off the same assembly line as Carrier, just different name tag
    Aug 2008
    San Clemente, CA
    We stock and use 3/4" rock base too, I just wonder if gardeners have the same "feel good using it" feeling when they have to mow around the stuff? Looking good. Glad to see the trap is serviceable. We use a deeper J-Trap and we slip plug a reducing 1x3/4x3/4 tee so a Gallo Gun fits in easier.
    Apr 2010
    NC Sandhills
    Looks good, I like it when people take time to make nice flashing. Most of the package units around here has flat top metal that ends up holding water and becomes a rusty mosquito breeding ground. Also, like Heils.
