Thread: BASRTP-B BACnet router
10-11-2012, 08:09 PM #1
- Aug 2001
- 209
My laptop I use with this device has been working fine until lately. I need to go into the settings to change my network number but i cannot get the router config page to open. I have windows 7 does anybody have any ideas?
10-11-2012, 10:18 PM #2
- May 2004
- SE Pennsylvania
- 515
As long as your computers IP is in the same range as the routers with the last octet being different and a good cable it shouldn't be an issue. Operating system shouldn't matter since it UI is web based.
10-11-2012, 11:13 PM #3
Worse case reset it to default, set laptop IP in default range, connect, reconfigure and disconnect.
kontrol out"Can't we all just get a Lon?" - Garry Jack
"BACnet: integration or interrogation?" - The Janitor
"Open protocols? You can't handle open protocols!" - Nathan R. Jessup
“What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora http://www.youtube.com/watch?v=U7fjDS0jKiE
10-12-2012, 08:55 AM #4
- Sep 2012
- New York, NY
- 43
I had the same problem and in the end it was an IP address conflict.
Make sure you set your computers IP address in the right range. for example my Bacnet router is 192.168.92.68 set your computer to 192.168.92.69
10-12-2012, 07:57 PM #5
- Aug 2001
- 209
Thanks guys it was the IP address conflict that was causing the issue. Working good now.
