    Oct 2012
    Pittsburgh,Pa
    trane xl 1200 heat pump
    Im working on Trane Heat pump xl 1200. when the unit goes into defrost should the emergency strips come on?
    Sep 2012
    Hebderson Ky
    Yes
    Aug 2010
    West Monroe, LA
    Yes it should!!! It is doing what is designed to. While the system is in defrost mode the heat pack should come on to supply heat to the home.
    What were you working on it for?
    Oct 2012
    Pittsburgh,Pa
    When the unit went in to defrost the emergency heat was not coming on. I have traced back to the dfc. Do you think this is the correct?
