Results 1 to 7 of 7
Thread: Capacitors
    Jul 2009
    WV
    Question Capacitors
    Starting fall checks and I would like to know at what percentage below the rated MFD you would recomened changing it out to a home owner. Thanks
    Nov 2007
    Mississippi
    10%
    May 2009
    Cumming, GA
    Check the label. Most are + or - .06%. But some are 10%.
    Sep 2012
    NW Louisiana
    Top of my head, MAX tolerance is 10% Run Cap, 20% Start Cap.
    CT
    Quote Originally Posted by Brent Ridley View Post
    Thats the manufacturing tolerance, that it could be off by when its brand new.
    Grand Rapids, MI
    We say could / should at 5 or 6 % and needs at 10%.
    Also, inform the client what motor the capacitor is connected to and may damage if too low.
    luck dan
    Yakima, WA
    Rule of thumb for the MOTOR's tolerance is 10%. As said before - the +- rating on the capacitor itself if the manufacturing tolerance. A 5mfd +- 6% could be 4.7 right out of the box.
