Page 1 of 5 12345 LastLast
Results 1 to 13 of 64
    Oct 2005
    Omaha, NE
    I will ask my HVAC tech to do routine checkup soon.
    But from owning different houses and different furnaces and watching them go through a few complete cycles, I have made the following observation:
    1. Thermostat calls for heat
    2. Electronic pilot ignites gas, temp rises until it reaches "Low-Limit" (around 120F)
    3. Fan kicks in
    4. Burners continue to work, temp continues to rise until it reaches "High-Limit" (around 180F), then the gas is cut off, fan continues to run until it cools down to minimum (around 120F) then furnace shuts off.
    My questions are:
    a. Is it normal for furnace to reach High-Limit on every cycle?
    b. Is it a good idea if the HVAC tech adjusts the GAS VALVE down a bit so when burners run, they do not heat too much causing the HIGH-LIMIT switch to trip?
    Potentially saving gas and money?
    Thanks.
    cn
    1991 Tempstar 80% Furnace
    If your furnace is going out on limit then you have airflow problem.
    Or you are keeping the stat setting way above 80 degrees.
    Its could be overfired but, I doubt it.
    Oct 2005
    Omaha, NE
    Furnace well-maintained
    -Air Filter changed often (every 3 months)
    -Thermostat set at 68-69F.
    3. Fan kicks in
    [/B]
    What you have posted does not indicate that the furnace is goingout on limit.But actually it sounds like that stat is taking it out.
    Oct 2005
    Omaha, NE
    Actually I watched the cycle
    3. Fan kicks in
    What you have posted does not indicate that the furnace is goingout on limit.But actually it sounds like that stat is taking it out. [/B]
    and see the dial in the Limit Switch keeps rising until it hits the HIGH-LIMIT, then the flame goes out but the blower still runs.
    If you see it going out on high limit,then I don't doubt it.
    Going out on high limt is likely due to lack of air flow,as stated above.
    Furnace has X btus of heat,if air flow is not sufficient ,the furnace gets too hot,and goes out on the limit.Not what you want to have happening.
    Might want to try it for aa few minutes without the filter,this will aloow a little more air flow,so it should run longer,or not trip the limit.
    What type filter do you use,if it's a 3M ,that could easily be the problem.
    Oct 2005
    Omaha, NE
    Yes using 3M (or similar Filtrete)
    I will try to run without the air filter and see what happens.
    On the other hand, I'd like to see furnace tuned so at peak operating temp, it should be around 160-170 F or so, but not 180F that trips the high-limit.
    Jul 2005
    Cn; If your furnace is reaching it's high limit setting (1800 then it is due to one or all of the following;
    obstructed/dirty filter.
    restricted return air
    fan speed set too low.
    Several supply air dampers /registers, or runs are not fully open and are causing too high a temperature rise at the plenum or near the heat exchanger, thus tripping high limit.
    Normally on a T stat call for heat the burner will fire up,then a few minutes or so later at approx 120-130 degrees in the plenum the blower will kick in. The burner will continue to run until the T stat is satisfied, then shut off while the blower continues to run until the supply plenum temp gets down to approx 90-95.
    Some questions for you;
    When did this "high limiting" start occuring?
    Did it just start acting up like this overnite.Have any adjustments been made to the system which would cause this problem?
    What size is this unit (btu output) and what size of home.?
    [/B]
    None of the above will cause a high limit problem.
    Oct 2005
    Omaha, NE
    I have noticed this to be the "normal"
    cycle during the last year that I own it.
    Serviced by HVAC (not sure they watch a complete cycle).
    I will ask if they can adjust the gas valve down a bit.
    All registers are open.
    Blower healthy blowing lots of air
    I will try w/o the air filter and see what happens.
    Maybe it was over-adjusted from day one (1991)!
    Probably no harm as the high-limit shuts the burners instead of the thermostat.
    Iowa
    i got a call about this happenin also, went to the house she had rugs covering the return air grills, plus all the registers were closed. took the rugs off and opened the registers problem fixed.
    Doubtful adjusting the gas valve is the real solution.
    You more then likely have an air flow problem as others have said.
    Your dust work can still be undersized and the regs blow out alot of air, because there aren't enough of them for the furnace size.
    Your furnace is probaly over sized for your house and duct system.
    Florida
    Tripping out on high limit,wanting tech to adjust gas valve, you need a service call, where airflow/safeties are checked and valve/combustion can be dialed in.
