    hishizaki ice machine
    404a hoshizaki ice machine.
    What evaporator temperature or
    Saturated suction temperature should i see?
    Usually a freezer is minus 20
    I assume an ice maker is less?
    It is at zero lbs
    Or about minus 48*
    too low bro
    around 15˚
    Oct 2011
    Chicagoland Area
    Depending on conditions you could see freeze start out at 50psi +/-5psi and at end of cycle 30psi +/- 5psi
    Thanks you guys!!!!!!
    Looks like i got a tiny little TEV to replace!!!!!
