Results 14 to 26 of 37
    Jun 2001
    Oklahoma City
    I've found in most cases you can just leave the 2nd stage unhooked completely since furnaces are typically sized twice as big as needed. Set the system as "two stage" and never use stage 2.
    Rochester NY
    If it is a GMH, you can't use a 2 stage stat
    +1
    Not really a 2 stage furnace. Won't be polishing that one...
    Quote Originally Posted by 54regcab View Post
    The fact Goodman makes a 2 stage furnace w/o the capability to be optimized with a 2 stage stage leaves a bad taste in my mouth about Goodman...
    Hmmm. Not sure that's fair.
    Sad but too true. Most with multiple stage furnaces spent xtra and got nothing for it. GMH at least is cheaper than a real 2 stage furnace.
    Dec 2010
    It can also happen during recovery from setback.
    I had not thought of that, but so true.
    Lancaster PA
    Quote Originally Posted by tedkidd View Post
    +1
    It IS a real 2 stage furnace. It has 2 stages.
    Rochester NY
    It is a "modified 2 stage" system. Low can run for the first 5 minutes, or 1-12 minutes at the BEGINNING of the cycle. To me, this is a soft starting single stage.
    I guess technically it is a 2 stage, but it misses 90% of the benefit of 2 stage. Any furnace that can't run high first then low, in my view (energy and comfort), misses the point. Ideally a 2 stage can cycle back and forth, modulating in an attempt to match envelope losses.
    (http://site.mypointnow.com/documents/25-k120602.pdf p12. Also, notice it doesn't even list a low output on spec sheet. )
    The real problem comes in when the sales person who like to oversize doesn't understand how this turd operates. He figures he can size to low stage and have "high for fast recovery". Now you have a grossly oversized piece of equipment you can't even lock on low.
    I Audited a house with one of these. 2200 sf, 120,000 btu. Client replaced a 30 year old furnace a year before I got there (same size of course). Bill analysis showed NO ENERGY SAVINGS and they have all kinds of comfort issue.
    IMO, calling it 2 stage is like painting a dog turd gold and calling it a gold brick. Makes true 2 stage devices look bad by association.
    Fort Worth, TX
    I can see the timed two stage approach working correctly if:
    a) The high stage is sized for the winter design day (not low stage)
    b) Setback swings are minimized or eliminated
    c) The building envelope is above average in thermal integrity (including duct leakage)
    I would agree with you, Ted, that if the furnace high stage is being sized for "fast recovery", that's foolish. How is "fast recovery" quantified in engineering terms? "Oh, it should warm your house back up from 55 to 72 in about fifteen minutes". Sure, if you have a volcano blazing away inside the box, that might happen.
    The benchmark is the winter design day, not sizing low stage for winter design and then relying on high fire for setback or other recovery demand.
    - Homer Simpson
    Rochester NY
    What it does is provide a gentle start. It puts some btu to the duct so that when the fan ramps up it's not blowing really cold air at max velocity.
    But imagine my frustration spending hours trying to figure out how to manage staging so I could help improve comfort and energy consumption, and my disappointment when I finally understood what this thing is.
    It's the epitome of "heat UP and shut off" design philosophy.
    Fort Worth, TX
    If the furnace is sized correctly for the structure, do you still see this control strategy as problematic?
    - Homer Simpson
    Rochester NY
    As I watch my grossly oversized furnaces quickly satisfy my rental units and shut down even with a 2f deadband, I have a hard time imagining ever recommending single stage appliances. "correctly" sized means it's oversized all but a few hours of a few random days during a season.
    So I'm not a good one to ask.
    Fort Worth, TX
    The way I see it, residential heat load calculations came of age in a time when single stage equipment, heating or cooling, was the norm. Sizing correctly for that 2% slice of the year does mean the equipment is oversized 98% of the time, provided the equipment can actually deliver the amount of BTUs a "design day" situation calls for. For gas/oil heating this is usually done in spades; for a/c and heat pumps, it can get very close, or even come up short.
    - Homer Simpson
    Dec 2010
    The older Goodman's 90+% (and maybe other brands), without the variable-speed blowers, did not have 2-stage blowers. They blew hard on "low stage". You get what you pay for, generally speaking.
    Lancaster PA
    A dog with3 legs is still a dog. A 2 stage furnace weather it can be controlled by the stat or not is still a 2 stage furnace.
    Although I'm not a fan of the GMH. When sized correctly. And used with a stat that is CPH based. It runs in first stage a majority of the year.
    There's lots of other 2 stage furnaces installed there controlled by the thermostat, but there over sized so they don't get long run times anyway.
    Rochester NY
    CPH. That's a trick I never dug into. Im trying to get my head around it. (ObeewhanBT, how could you not have taught me about this before now!)
    Set board for long first stage? Limit CPH to drive cycle time up? Sort of like setting larger deadband?
    What other fun stuff do you use CPH for?
