Results 14 to 17 of 17
    Apr 2012
    winnipeg
    a jumper wire
    when the heat is supposed to be on, is the thermostat showing that the heat is on?
    room temp=62°
    set to 63° or higher
    does thermostat indicate if the heat is on, does it make a click sound or show a little flame in the display?
    if stat is not activating, the that is the place so start. if stat is working, then look to the furnace or wiring.
    Mar 2009
    Mount Holly, NC
    Quote Originally Posted by shankle View Post
    How would all this explain why a/c works fine, just not the heat?
    Is there a specific stat i could use to bypass this problem?
    Thanks !
    why would a furnace heat source affect the room when in cooling mode?
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    Philadelphia, PA
    Have you called the installing contractor back to check it? If so, what did they suggest?
