Results 1 to 13 of 27
Thread: Leak Lock
    Sep 2006
    Ohio
    Leak Lock
    Has anyone found a thread sealer for refrigerant fittings that is better than Leak Lock. Over the years I have found a lot of refrigerant filter shell covers that have leaks around the threads of the brass MPT connectors. I have always used Leak Lock on the threads in the past and sometimes it works and sometimes it doesn't.
    NC
    There's a thread about a product called 'Nylog'. I've never tried it, but other guys say it is better than the blue stuff.
    Quote Originally Posted by ncboston View Post
    Nylog is pretty good stuff.
    On a fitting that is going to be PERMANENT, I suppose that LeakLock is OK, but if there's a chance I'm going to want to take it apart, I'm using nylog.
    Jun 2012
    nampa idaho
    The nylog is great stuff but you have to use different ones for r-22 and 410a, so it has worried me with cross contamination, but it is impressive and does work better than leak lock
    Quote Originally Posted by hkempf View Post
    The HFC version is backwards compatible.
    No need to carry 2 bottles.
    up in the hizzy
    Jun 2008
    Windsor, Ont.
    Ditto on the loctite 554, doesn't come apart easily but it works great.
    NH
    Nylog works well... But I like using loctite 567 on those drier core fittings...
    Also works great on those old discharge gas thermostats on 06E compressors. Leak lock will never seal those.
    Mar 2009
    Mid-Mo
    Quote Originally Posted by Dchappa21 View Post
    X2
    I carry tubes of both on my truck.
    Salt Lake City/Tooele
    I HATE LOC-TITE!!!....used it for ohhhh soooo many years, and if it gets hot or cold it will eventually leak. Works wonders on those hot discharge plugs and head sensor threads. Awesome on discharge/suction service valve cap threads, and on any gasket or O-Ring I install.
    NYLOG is true nectar from the Gods. Will NEVER go back to LOC-TITE.
    Jun 2012
    nampa idaho
    Thank you jpsmith I was wondering about that but all the info I find I vague
    California
    Quote Originally Posted by hands View Post
    In this situation, it's hard to beat a combination of.
    Teflon tape & loctite
    May 2010
    Oxford, UK
    Can't stand Leak Lock! Got called to look at a walk in cooler that previous tech had covered the txv connections and orifce in the stuff, no room to do anything, took ages to clean it all of as it sets like stone.
    Been using Tru-Blu by Rectorseal for years on taper threads without any problems, comes apart again if needed.
