Results 1 to 13 of 21
10-09-2012, 01:28 PM #1
New Guest
- Oct 2012
- 5
Honeywell Pro4000 T-Stat Compatible with Trane XV80?
Hi,
I recently had a new unit installed in the upstairs of my house that included a Trane 3 Ton XR15 and XV80 80K BTU Variable speed furnace.
The thermostat that was installed is a Honeywell Pro4000 (Model # TH4110D1007.) I had several issues during the install that caused me to no longer fully trust the HVAC Company.
They claim this T-stat is a match for my system (I assumed I would be getting a Trane T-stat but it was not specified in the quote.)
Can someone tell me if this is a compatible T-stat with this system to get its full capabilities?
Thanks!
10-09-2012, 02:25 PM #2
I am not a "Trane" guy but I am a fairly seasoned hvac guy. The stat is single stage heat, and your furnace is probably a 2 stage heat furnace. Which means it can run at a lower btu. rating and if it needs to, kick into a higher btu. furnace (give you more heat).
You could have a 2 stage thermostat do this for you, but I prefere the furnaces "timer" to do it. Which means that if the furnace is on for ten minutes and doesn't satisfy the stat the it automatically goes to "high" fire. Its possible that you don't have enough strands at the thermostat from the wire to do a 2 stage furnace, so yes, the thermostat is OK and capable. You would need to listen to the furnace for 8-12 minutes to hear it shift up to see if your contractor flipped the dip switch for this option
BTW, sound like you chose some nice equipment.As iron sharpens iron so one man sharpens another Proverbs 27:17 NIV84
10-09-2012, 03:28 PM #3
Its compatible. But it can not give you the full benefit of the furnace you have.
10-09-2012, 03:30 PM #4
Professional Member*
- Oct 2012
- Toronto, Ontario
- 67
This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
Further infractions may result in loss of posting privileges.Last edited by beenthere; 10-09-2012 at 03:46 PM. Reason: Non Pro * Member
10-09-2012, 03:46 PM #5
Steveo86, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
Your post has been deleted.
10-10-2012, 08:48 AM #6
New Guest
- Oct 2012
- 5
Thanks for the responses.
Any suggestions on what T-stat I should ask them to replace it with that can give me the full capabilities of the system?
10-10-2012, 11:14 AM #7
If there are enough strands of wires at the thermostat, or a new wire can be pulled to this location, then any 2 stage heat thermostat will work. I really like Honeywell thermostats. If there are not enough strands and a new wire is impossible to pull, then Honeywell makes a thermostat called an "IAQ" thermostat. I am sure you have enough strands for this one. But keep in mind that the current thermostat will work and give you all the benefits, the only difference is that the thermostat doesn't control the 2nd stage heat, but a timer in the furnace does, and I like to have the timer do the work instead of the thermostat. That's my preference.
The IAQ stat can also have an optional outdoor thermistor added to it to always display outdoor temperature on the screen. And if you have a humidifier, than the thermostat can operate the humidifier with more precise accuracy than a conventional humidistat would. They are pricy though but it is the best thermostat out there. It also has other features too.As iron sharpens iron so one man sharpens another Proverbs 27:17 NIV84
10-10-2012, 12:00 PM #8
- May 2012
- Germantown, MD
- 21
10-10-2012, 01:52 PM #9
Yes I can. I have had some customers, usually older folks, where the thermostat is calling for low fire for 30 minutes and they complain that the old furnace never ran that long. So where the timer does the 2nd stage, then after 8-12 minutes it steps up to high fire and satisfies the thermostat quicker. Also i have had 2 stage furnaces where the installer didn't set it up correctly and it has only fired on low fire and since it wasn't wired correctly, they complain that the new furnace ran their gas bill up.
10-10-2012, 05:20 PM #10
A timer is like having a toggle switch for the heater in your car. When the car is cold and needs the most heat, you turn it on low. Then when the car warms up, you turn the heat to high until you can't take it and then turn it off. Over & over. We sold the he!! out of the 2 stage 80s then 2 stage 90s when they came out. All went on 2 stage stat. I can think of 1 old lady that had trouble, the rest all raved about the comfort, especially on a bitter cold morning when the furnace ran non stop. After all, that's what you do in your car. You find a gentle low level and never shut it off.
The problem is, most dealers cripple the expensive furnaces the customers paid for without educating them on the comfort level they could have. These days 2 stage stats are hardly any more than single stage. Click on that purty touchscreen that appears in the ad on the right at times.
10-10-2012, 08:51 PM #11
New Guest
- Oct 2012
- 5
10-11-2012, 08:26 PM #12
- Jun 2001
- Oklahoma City
- 2,591
If your furnace is oversized like most you can just disable the 2nd stage entirely. It isn't needed for most installs. A 2 stage stat would be handy for faster recovery from setback.
10-11-2012, 08:36 PM #13
Yes, I am a firm believer in a 2 stage stat. The comfort advantage in bitter weather is there. When it gets bitter cold, why constantly cycle between low, high & off? A gentle low for long run cycles keeps you so much more comfortable. Just like you do in your car.
