Results 1 to 2 of 2
    Oct 2008
    Low/med/high fire set-ups
    Can someone explain the difference between these settings in a furnace? My model is OH6FA072DV4. Curious on my ECM fan speed settings. Currently it's set at factory setting:
    Heating CFM: 968
    Low fire rise: 57 deg
    Med fire rise: 69 deg
    High fire rise: 86 deg
    I'm curious as to what those numbers mean and if my house would benefit from either a change in dip switch settings and/or a different nozzle (currently have .60 x 80A)
    I'm in New England in a 2 story colonial built in 1949 with updated windows and 1700 square feet.
    Quote Originally Posted by chigundo View Post
    Heating CFM: 968
    They are air temperature rise measurements and should have been varified when the furnace was commissioned and set up with a combustion analyzer. There is no other proper and safe way to set up an oil or gas furnace.
