Results 1 to 9 of 9
Thread: 3 WIRE PILOTS
    Dec 2011
    Twin Cities Minnesota
    3 WIRE PILOTS
    These old systems always cause me "Brain Freeze". Anybody have any good trouble shooting info on them? Have one lites the pilot.,but not the burners.Will run that way for days! Thanks ahead!
    Aug 2009
    Beatrice, NE
    Ussually that is caused by a dirty pilot. The pilot flame doesn't get hot enough to cause the bi-metal strip in the pilot to warp. If a good cleaning doesn't do it, replace it.
    Houston,Tx.
    Quote Originally Posted by kls-ccc View Post
    Usually that is caused by a dirty pilot. The pilot flame doesn't get hot enough to cause the bi-metal strip in the pilot to warp. If a good cleaning doesn't do it, replace it.
    +1
    Virginia
    Quote Originally Posted by Cosmicmuffin View Post
    Agree with the others.
    If you want more info on how these pilots work, to help in troubleshooting, send me an email (address is in my profile).
    Wisconsin
    Just had a dirty one saturday night. Cleaned her out, worked fine after that. If you need to replace it, go with oem. I got burnt once by non oem, never again.
    Jun 2007
    Greenwood Indiana (Indianapolis)
    Here is a helpful hint.
    After the pilot lights from the spark, unplug it and you can jump the yellow and white wire to test it. The gas valve should then open up. This is ONLY a TEST
    As iron sharpens iron so one man sharpens another Proverbs 27:17 NIV84
    SE Michigan
    For the next 60 seconds?
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Dec 2011
    Thanks guys.,brain thawed out.,went back cleaned pilot orfice ,now work'n fine!
    there is some good info on this site with links.
    I made a pilot/gas valve device to test each with help from this site.
