Results 1 to 7 of 7
Thread: amana trouble
    Oct 2011
    amana trouble
    Got a amana that when it lights it fires off and then stops then lights again, all within a second, i am not losing power to gas valve nor am i losing manifold pressure, has a new ignitor, it makes you sit back when u are watching it. it is almost like the flames get sucked away from the burners for a split second.
    Oct 2010
    Anderson SC
    It's probably a problem with flame rectification or a grounding problem. Get a qualified tech out to diagnose and repair.
    Calgary, Alberta
    So it's rolling out? Or lifting off?
    Nov 2007
    Mississippi
    No DIY
    Lancaster PA
    Moved to Tech to Tech Residential forum.
    Lancaster PA
    mrfixitright. You have the post count, apply for pro membership. Much more detailed info in the Pro forums.
    Get your manometer out, and check the pressure your switches are seeing.
    Cincinnati, Oh
    Time to put that GUX out to pasture.
    "Just get it done son."
    Dad adjusted
