Results 14 to 26 of 27
    Atlanta GA area
    Had one a few weeks ago...
    Guy refused to sign the ticket stating CO leak and dangerous situation... I told him I would have to call the gas co... they would shut off the entire house... no cooking and no hot water. He signed.
    I realize no heat is not comfortable... however why folks take it out on us heat and AC folks is beyond me. We are trying to help... rather than hurt.
    I guess... well never mind... that would be an ARP comment...
    GA-HVAC-Tech
    May 2012
    Upper Michigan
    That thread needs to make a comeback!!!
    He never declined doing the work, he just stated " I find such things". I would be like hell no I didn't fix that thing.
    May 2012
    Upper Michigan
    That's good. I want a signature also. The last one the lady still wanted to run it, being a pulse they are positive pressure I wasn't to thrilled. I told her she could die or get sick, she told me well I've lived with it this long. She signed the paper but I found out later she ran it. We put a new trane xv95 in within a few days.
    Atlanta GA area
    On occasion I will loan someone an elec space heater (after they sign a contract for a new furnace)... however:
    I have taken it apart and dis-abled the high setting. Reason is I do not want a 1500 watt (12.5 AMP) draw on a circuit in their house.
    I explain this to them, and to always plug the elec heater to either a kitchen or bath outlet... Ni issues so far.
    GA-HVAC-Tech
    May 2012
    Upper Michigan
    We have around 12 heaters, I tell them to use different circuits if they can, and tell them they will over load and pop breaker or fuse if they have to many running. My bedroom is on a crawl, I made the mistake of putting on in there for my wife to temper the room, now it just runs all night. She is one of them people that are freezing while your sweating!
    Nov 2008
    DFW,TX
    why would that qualify as wall of shame, thats just good work finding it but noone did anything shady, yet )
    May 2012
    Upper Michigan
    There's a new rtu up there now.
    Jun 2012
    Had one today where the customer wanted a quote. When I get there they said "A competitor found the problem!" like they needed a trophy. They wanted multiple estimates on it. It cracked me up because they just acted like it was a secret trap.
    Seeing it was a carrier RTU the first thing I did was pull the blower door and shove the phone in... (Bottom left seam going)
    That was normal no biggie...
    Then went to check operation so I pulled comp panel door and wow!
    I could stick my hand in the hole around inducer assembly.
    I would put money on it if it was serviced once in it's life it would be looking like that.
    May 2012
    Upper Michigan
    Wow that might give you a headache lol
    Dec 2008
    Buffalo NY
    Quote Originally Posted by Freightshaker View Post
    Good old carrier. Seen that many times. They keep you busy. I heard they are now offering stainless street heat exchangers. Is that true?
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Jun 2012
    Yeah! Flames rolled from bottom to top too.
    Jun 2012
    Quote Originally Posted by qwerty hvac View Post
    Not sure on that. I know they are like changing a gun clip though. At least they are easy. I do not use their fiberglass gaskets anymore. Just high heat silicone. It doesn't hold moisture like the factory ones... seems to keep them from corroding at Mach 5 in gasket areas.
    Carrier = job security
    Sent from my SGH-T999 using Tapatalk 2
