    Magic chef Pacage unit
    I am looking at a Magic chef Package Unit. there are no readable model, ssn or sizing markings. The compressor is a copeland Yrb4 0301 s/n 781 09769. that is the best I can read it due to corrosion.
    The burners are toast but the heat exchanger does not show signs of being cracked or have holes.
    Supply houses are closed for the day. Does anyone think I will be able to find the burners?
    BTW I am a contractor but have not come accross Magic Chef air conditioning systems.
    thanks
    Anderson SC
    If you
    Mount Airy, MD
    Relocated to Tech to Tech
    Sep 2003
    You could try this link but you really need the Model and Serial numbers for this unit.
    How else would you get the correct burners.
    http://www.magic-pak.com/locator.php
    You might have to change that entire unit, One tip if you do.......Remove the cooling chassis before moving it up or down stairs. Then reinstall cooling chassis. Your back will thanks me for it later.
    Magic Pak is made by Allied Air
    thanks.
