Results 1 to 4 of 4
    Goodman heat pump package unit
    At first i thought the unit was low on freon and it was. A slow leak in the condenser coil nothing major. It has not been very hot in my area for the past couple weeks until a day ago. It got into the mid 80s. I noticed that there was on about a 8 degree split checked pressures again and not low enough to make that much of a difference. I should be getting a lot more than that any ideas?
    Mount Airy, MD
    Thread relocated to AOP
    Dec 2012
    Jul 2003
    Orange County N.Y.
    Quote Originally Posted by sub cool View Post
    Not enough information.
    Sir, you could have one of a possible hundred things wrong with your system. The only way to repair it is to have someone with knowledge onsite to determine exactly what is wrong with it by using their 5 senses and proper refrigeration pratices. Any other way usually ends up in frustration, excessive expenditures, and higher costs to operate your equipment.
    ...Ron
    Roof Rat
