Page 3 of 3 FirstFirst 123
Results 27 to 29 of 29
  1. #27
    May 2008
    South Florida
    Smile
    What about the chance of copper shavings getting into the system and causing another restriction?
    I said drill, but what I would really do is pop a small hole in the suction with my torch
  2. #28
    FSE_ that's a weird couple of posts. Have you done either of those things with the drill or torch before
  3. #29
    I think an ice pick shoved thru the copper would be best , then shove cap tube into it
    On the condenser end , cut the suction pipe in half , drill a hole through a coupler , pull cap tube thru pipe , shove through hole in coupler , put coupler in place.
    All theory and sounds easy of course on paper ....
