Results 1 to 13 of 29
    May 2005
    it's 2:45 am.......
    and i cant sleep thinking of this stupid turbo-air 2 door freezer i put a
    compressor in a couple weeks ago..after i did the work i told the customer
    to never call ME again on this pile!..( i havent billed him yet) he calls me
    to say he's sorry but the thing is running at 20*.....
    this thing has a 2 part cap tube and the one that runs through the wall is a ice ball
    at the evap and cold at the connection where it comes through the wall and connects
    to the cap tube going to the compresor.
    have any of you guys replaced said cap tube that runs through the frickin wall?, and
    what are the chances of blowing CO2 through the tube to clear it?
    *yawn*
    Dec 2000
    Flat Rock, NC
    try just cutting the infeed end off as this is normally where blockage is. just shorten it by an inch and try it.
    Jun 2009
    DFW, TX
    We typically run a new cap tube up the back wall, drill a hole through the box, and then silicone the penetration afterwards, its actually not too bad. I've done it on several True's but never on a TurboAir.
    May 2008
    South Florida
    Quote Originally Posted by trippintl0 View Post
    Another way without penetrating the box: Drill a hole in the suction line by the evaporator. Cut the suction line by the condensing unit. Feed the cap. tube down the suction line. Solder it all back together. New cap tube, better subcooling and no penetration through the box.
    Dec 2009
    Quote Originally Posted by FSE_ View Post
    I've never imagined that, but WOW, you must be an smart old man! I like your idea, not for this specific app, but this will be of good use when time calls. I like to make that hole in the wall and run with it. Nevertheless, I like your imagination, that's what I call engineering!
    Oct 2011
    Chicagoland Area
    What about the chance of copper shavings getting into the system and causing another restriction?
    May 2008
    South Florida
    Smile
    I said drill, but what I would really do is pop a small hole in the suction with my torch
    where it's nice and warm
    Do you think if you buy only the upper half of the cap tube you need, you will get it for half price. This is the only OEM with a two piece cap tube.
    Did you change the filter drier? Sure you have the correct charge? About clearing a captube it depends what is blocking it. I've only cleared a catube that was blocked with oil.
    I think there are too many bends in the suction to try and send a cap up inside the tube.
    I run a new one like trippint inside but I run it with a new suction line too. If you cover it with some metal they will like it better.
    I don't want to discourage you but its gonna be a PITA and a lot of time if you were never going back.
    Tampa Bay, FL.
    In my experience, your wasting your time trying to blow it out. Assuming that you cut off 1 inch of cap tube when you changed the dryer and drew a 300-500 vacuum, then the cap tube is probably waxed and only thing left is to change it.
    Have you considered just changing the cap tube between the drier and the sleeve?
    When we did warranty work for TA, had a cooler that had a clogged cap tube. Tech support told me to cut at the sleeve, blow nitrogen through both ways to try to see what section was restricted. The drier side was restricted, they sent out some cap tube, changed it, and it actually worked.
    It may have just been blind luck though.
    May 2005
    aramas, turboair suggested replacing only the visable cap tube,,,
    itsiceman, yes i replaced the filter, and weighed in the charge.
    76olds, ill try unsoldering the cap tube and blowing both ways...
    Jul 2000
    Guayaquil, EC
    For those who have never seen a TurboAir two-piece cap tube, here's an image from their TST/TUR service manual which clearly shows the sleeve referred to earlier:
