Results 14 to 20 of 20
    Houston,Tx.
    Quote Originally Posted by Hwolfe View Post
    I would check your amp draw on your motor after replacing capacitor to insure condition of the motor.
    Yes checking amps is a good thing, but I never check just amperage until after I have check voltage.
    "The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth".
    Sep 2012
    NW Louisiana
    Low voltage will make the amps climb... Then we find loose connections, and burnt wires, and well you know the rest.
    CT
    Changed cap ,motor hummed, gave blower spin to get going, noisy as hell, berrings are shot, going to replace motor. Thanks all for help.
    Houston,Tx.
    Quote Originally Posted by iceage View Post
    Changed cap ,motor hummed, gave blower spin to get going, noisy as hell, bearings are shot, going to replace motor. Thanks all for help.
    Motor runs hot on low mfd. cap. washes oil out of bearings, possible scenario.
    Jun 2010
    Miami
    I would be careful saying a run capacitor's main job is to correct power factor.
    I'd rather say the capacitor shifts the phase of one of the windings so that the voltage across the winding is at 90° from the other winding. The effectivly makes it a two-phase motor (when loaded).
    Now if the proper capacitor is used......then the currents through each of the windings, when fully loaded, should be equal....and under those conditions power factor will be close to 100%.
    Sep 2012
    NW Louisiana
    Quote Originally Posted by Russ57 View Post
    I agree 100%. In a nutshell, this is what I was trying to explain, but it did not come out as cleanly as you described. I was thinking about the phase angles and the reactance the capacitor adds to shift the angle.
    Thanks for the input. My wordiness probably confused some readers.
    CT
    Jul 2011
    Quote Originally Posted by nsula_country View Post
    1.2 mfd vs 5 mfd? This is off 76% of a 5 mfd cap. Most caps are (+/-) 5%-10% tolerance. Change is good!
    CT
    X2
