Results 1 to 11 of 11
    Tennessee
    Nitrogen regulator
    2nd generation commercial technician
    Mar 2009
    Triad - North Carolina
    A good quality company.
    Every problem gives us the opportunity to choose from several solutions: stupidity, ignorance, indifference, or brilliance. Which one will you choose?
    Apr 2012
    winnipeg
    looks neat......
    Richmond, Virginia
    Harris or Goss for a regulator?
    Tennessee
    Harris
    Salt Lake City/Tooele
    Just got this new regulator from Western Enterprises...............LOVING IT. Like their older generation regulators. I got the 250 psi model, this basically levels off the test pressure at 250psi max if you set and forget about it, or you just shut it OFF once you hit the test pressure you are looking for. Or if you are searching for a leak it will maintain 250 psi as your searching. There is a 500 psi model, but who knows why one would want that...300 psi is the max you would ever want before possibly damaging valves on compressors. The brazing feature is wonderful because it is self regulating. You have 20 joints to braze, with a regular regulator you will be going back and forth adjusting the pressure as you get down to just a few joints. This one you set it and forget it.
    http://www.westernenterprises.com/en...FS/VNintro.pdf
    Oct 2008
    Indianapolis
    Hope you have a better experience with the quality of Western Enterprises line of VN products than I have had.
    If were talking about the original VN regulator, I would agree. I liked the similar benefits of that regulator, but the design and the fact that it had to be attached directly to the cylinder, made it a pain. This new version is one of those things that has been so simplified that there is really nothing that can go wrong with it. This reg is one of those things that make you say, "why didn't I think of this".
    I am in love with a regulator for the first time.
    Oct 2007
    Miami, FL.
    Quote Originally Posted by slctech View Post
    Is the knob to tighten the regulator to the tank made of metal?
    I miss you mom and dad.
    The knob is molded solid plastic, not sure material but not cheap feeling. Not worried about it stripping on me. With the O-ring, no need to have to use a wrench to crank down to make the brass to brass seal as with other regulators.
    Jun 2009
    Ontario, Canada
    skip it. buy that new turbotorch with the gauge guard built in to them. it'll save your gauge in long run.
    Parts Changer Extraordinaire
    Have tools and gauges. Will travel.
