Results 1 to 13 of 34
    Oct 2012
    Urgent help needed: comparing 2 system
    For the past month the husband and I have been getting quote to replace our furnace that is older than us.
    We have narrowed it down to two bids. Both from good contractors. They stand behind their installation. Have good reviews and we have good feeling with both guys.
    It boils down to the equipment. So here goes my question to all of you hvac experts. Which one is a better equipment. I know equipment+installation is what makes a good system. But given the same expertise and quality in installation, which one of these furnace is just plain built better.
    Btw, both contractors quotes me for the same BTU, so I really just need equipment comparison, ie: quality, how easy it is to order parts, company customer service, etc.
    We already have an AC, and not replacing that. the AC is 2 tons. and these furnaces are 3 tons. Actually all the furnace quotes I got are 3 tons. And they all said that it can be adjusted or something. So I am guessing this is common practice.
    Anyways, these are the system I need help with.
    1. carrier performance 96
    2. trane xv95
    Since we have been getting quotes for a while, we would like to decide very soon. Thus, any insights is greatly appreciated.
    thanks
    Oct 2012
    a lot of views but no reply.... help.... we need to make a decision quickly. did i post in the wrong subforum or something?
    May 2012
    Upper Michigan
    How did they decide how many btu? Did they do a heat loss or gain? It really boils down to the installer, we deal trane and in the last 3 years only 1 call back.
    Apr 2012
    winnipeg
    I would not be able to choose either.... both are good products.... maybe flip a coin....
    The Trane is variable speed blower, the Carrier uses a fixed speed high efficiency motor. It is like a standard blower motor like a lower end furnace but uses considerably less power like a variable speed. Dealer and everything else being equal, the XV95 is a level above the Performance 96.
    Oct 2012
    this is good info. so "fixed speed high efficiency motor" is not equal to variable speed. I went to carrier website tho, and it says that it is variable speed blower motor. is their website inaccurate? I am a little confused.....
    http://www.residential.carrier.com/p...rmance96.shtml
    explanation is greatly appreciated.
    Oct 2012
    oh, never mind.... i guess the carrier model I was quoted for is actually 59tp5a that has multiple speed ecm. is this ecm motor the fixed speed you are talking about?
    Oct 2012
    one other question..... I have honeywell visionpro 8000 thermostat. both of these guys said that they need to pull more wires for the 2 stage to work. is it really the case?
    thanks guys.....
    Oct 2012
    thanks guys.....
    Apr 2012
    winnipeg
    could well be ... how many wires at stat now.....you will need a minimum of five....probably gonna be pulling more....
    Oct 2012
    I have 4 wires now. i did look at the thermostat manual and I need more. I was just wondering if there is a trick to go around this.
    so anyone can explain to me about the ecm motor that carrier has. is it different from the variable speed motor that trane has.
    I want to make a decision tomorrow, so I can get my installation in the schedule before the winter.
    Oct 2010
    ECM is the same with any brand, x13 is the fixed speed high eff motor. Both manufactures make quality equipment. I suggest going with whichever contractor stood out more or flipping a coin.
    Sep 2012
    comparing 2 system
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    You can find the rules for posting and qualifications
    here.
    Further infractions may result in loss of posting privileges.
