Results 14 to 16 of 16
Thread: btu math help
    Virginia
    Quote Originally Posted by oliesteveo View Post
    here is another one 13080 btu were removed from 10 lbs of water at 218 degree f what would be the temp of the water
    Did you come up with this answer?
    Two hints:
    Specific heat of steam is 0.5 BTU/lb∙°F
    and
    Latent heat of Vaporization is 965 btu/lb (change steam to water).
    Oct 2012
    i used 144 and 970 btu for the change of state came up with10 degrees
    Virginia
    Correct.
    Nicely done.
