Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 45
  1. #27
    Southeastern Pa
    What, no visit from the OP??
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  2. #28
    Southeastern Pa
    tick..tick..tick..tick........
    Ya ever notice how some posters come here and ask a coupole of questions, and when we ask for more info, they never come back?
    Why is that?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  3. #29
    Southeastern Pa
    (sound of wind whistling down an empty street in an abondoned western town.....a tumbleweed rolls by.....)
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  4. #30
    Oct 2011
    Chicagoland Area
    Can I expect an update from you everyday timebuilder?
  5. #31
    Hacienda Heights, California
    Sorry been busy...i will post model # and serial# today
  6. #32
    Delfield 3 dr reach in model # SLF72-S serial #397171-T....its diffecult to test head pressure on second start up cause it dont stay on long enough cause it hums and trips breaker.There fore pressures are hard to determin.I will try to update my post since i am the OP...and all advise is greatly appreciated.Thanks so much
  7. #33
    Timebuilder to answer your question this unit does pump down...it has a LLS...
  8. #34
    This unit has a split evap with 2 txv's...way more complicated then it needs to be.Traulsen is way more simple...
  9. #35
    Southeastern Pa
    Quote Originally Posted by 2sac View Post
    Think I have enough posts to cover every day?
  10. #36
    Southeastern Pa
    Quote Originally Posted by supercooljim View Post
    Just off the top of my head that looks like a True model number.
  11. #37
    Apr 2010
    DFW
    What's the voltage at the compressor at start up? Does it drop when there's a load on it? If not, ohm out the pump. If it ohm's out ok, change the start components first before you condemn the pump.
    X2. Check for voltage drop at the contactor. If no voltage drop there, check the breaker. If you find the source of the voltage drop at either of these places, replace that component.
  12. #38
    We are currently in the process of just wiring everything in a more mechanical fashion...will see what happens...kinda like the older model Traulsen reach ins
  13. #39
    Apr 2010
    DFW
    Translation: we didn't find the problem.
