Results 1 to 10 of 10
    Nov 2011
    GA
    experimental vacuum setup
    took ball valves off hoses so there were to core depressors in any hoses
    Pulled cores out, took about 10 minutes to pull down to 500, about 15 to pull down to 280, closed ball valves on core tools, killed pump and let sit for 20 minutes. And 570 is what i got. installed cores, pulled vacuum down again, let urr rip. Good enough for me!
    LIFE IS TOUGH, IT'S EVEN TOUGHER IF YOUR STUPID!
    I like the tee idea.
    Sent from my HTC Sensation 4G using Tapatalk 2
    Mar 2009
    Mid-Mo
    I have the parts to build something just like that sitting in the back of my van!!
    Nov 2011
    GA
    Quote Originally Posted by david912 View Post
    i meant "no core depressors"
    Nov 2011
    GA
    It suprised me how good it worked, saved a bunch of time, If anybody makes one make sure you raise or lower the tee a little bit, when i made this one i didnt think about it being so close to the handle of the pump. other than that worked great! I usually put it in a vacuum and pick up all my stuff and put everything back together, now my vacuum is done before i finish picking up
    Mar 2009
    Triad - North Carolina
    I like it. Every fitting and 'seal' you can eliminate will always help.
    Mar 2009
    Mid-Mo
    This is on my list of things to do when I get back in the office on Wednesday.
    I already measured mine out so the handle isn't an issue!
    Nov 2011
    GA
    There you go! ill probley repipe my tee and ill be good to go. works like a champ anyhow
    Oct 2012
    New Hampshire
    Good work! Definitely giving this one a try considering the lengthy time it seems to take pulling a vacuum on some 410a systems.
    Sep 2012
    NW Louisiana
    I like.
    CT
