Results 1 to 13 of 20
Thread: gas piping
    Apr 2012
    winnipeg
    gas piping
    ripped out a mess and installed this.... not finished ..work in progress....
    Oct 2009
    Mukwonago, WI
    looks nice. why so many pipe supports? what do you use to paint the pipe?
    Jun 2002
    south jersey
    Nice job. I love the look of a job after you paint the pipe.
    You need to put the phone down and get back to work!
    Apr 2003
    Maple Grove, MN
    What's the deal with all of the extra 90s and pipe nipples, why not just go straight out the side of the pipe? Also, why the weird random spacing of the pipe blocks? One more thing, if that is a rubber roof, you should push the rocks away from under the pipe blocks before you put them down, to minimize the risk of damage to the roof. O.K., maybe the last one is pushing it a little, but I think that is the proper thing to do, especially if you were to be supporting something heavy (like a condensing unit sitting on couple of 4x4's).
    Other than that, nice clean looking paint job. Is that black pipe or galvanized under the paint?
    Apr 2012
    winnipeg
    we have to come off a branch to a unit like that by code....... the blocks are randomly spaced because we were not finished.... have never seen rocks removed from under blocks....its black pipe....
    Nov 2001
    Moose Jaw, Saskatchewan, Canada Occupation:Interprovincial Plumber, Commercial Gasfitter Interests:
    what's the code reference? Local?
    I love my job, but paydays Thursday
    Apr 2012
    winnipeg
    B-149.. its in the Manitoba gas notices.....
    Nov 2001
    So not 149, but specific to Manitoba.
    Apr 2012
    winnipeg
    that is correct....
    Calgary, Alberta
    So you guys in Manitoba have to point your tees up for a branch line? Weird.
    In Alberta we aren't allowed to have drip legs outside, and they make us support anything under 1" every 4 feet, plus on both sides of every fitting.
    Looks good though!
    Apr 2012
    winnipeg
    yep must point up.....we don't use drip legs or dirt pockets outside either... and we must support bot sides of joint as well..... picture was taken before all blocks in place and clipping...... some of the rules are wacked out.... oh well.... only follow them.....don't make them
    Nov 2001
    We have to have drips. The real question is why do those responsible for adopting the codes think they know more than those who write the codes?
    Rochester NY
    Quote Originally Posted by jnsrose View Post
    + ...3? or is it 4. packages look nice too.
