Page 3 of 3 FirstFirst 123
Results 27 to 30 of 30
  1. #27
    Apr 2001
    Over Here
    Ok, standard control.
    I took it that it was controlled by an od dew point controller... Which is something I'd like to find. I'm still searching for a cost effective digital version to work with your ventilating dh's.
  2. #28
    Rochester NY
    Quote Originally Posted by thermojohn View Post
    Why? Proactive rather than reactive?
    What benefit to you intuit there would be?
  3. #29
    Apr 2001
    Over Here
    Quote Originally Posted by tedkidd View Post
    Well, since I am an energy efficiency nut... If there is a need for dehumidification, and the OD dew point is below 50, I want the ventilation fan and damper to operate, and leave the compressor idle. I took it from TB's earlier post that he was doing the something similar, and was curious on the control he used.
    I did this to my own ventilating DH, and it works absolutely superb. The controller I'm using is an old school Carrier dew point controller that is no longer available.
  4. #30
    Madison, WI/Cape Coral, FL
    It is getting complicated. First, if the home is occupied, the home should be getting a fresh air change in 4-5 hours. This is regardless of the outdoor dew point. When the outdoor dew point is low, the moisture from the occupants is purged and the indoor %RH will be <50%. As the outdoor dew point rises, the indoor %RH will rise. Without any cooling load, the dehu will run.
    If the home is unoccupied, the indoor %RH will respond to the outdoor dew point. So ventilate when occupied and dehumidify when +50%RH.
    You have a good case if you have an indoor moisture source that is not occupant related. Fish tanks and open pools is a good example. I am not aware of any inexpensive dew point controllers.
    We currently do not have a dew point controller but could do it based on outdoor temps and %RH.
    Appreciate the comments and support.
    Regards TB
