Page 4 of 4 FirstFirst 1234
Results 40 to 42 of 42
  1. #40
    Mar 2012
    Sandy Springs ,Ga
    i have seen pump down systems that utilize a relay that is energized by out side of compressor contactor , this is done to prevent heaters from coming on during defrost , which creates high current draw and can cause breaker to trip on single units . as far as pump down goes . low psi control should be set at approx 5psi . As
    others have mentioned use gauges to verify . the schematic supplied should help out ... if none available trace wires these systems are usually very simple .
  2. #41
    Feb 2012
    Toronto Canada
    How about billing the customer for extra time cause you have to pull out your cell to ask HVAC Talk How to fix it ?
  3. #42
    Jan 2010
    Quote Originally Posted by OldSchoolMech View Post
