Results 27 to 39 of 42
  1. #27
    Oct 2011
    Chicagoland Area
    To the OP. Slow down. Read your wiring diagrams. They tell you everything you need to know.
  2. #28
    Jan 2010
    Hold on a second, you do refer work too??
    Looks like he found the right defrost timer didn't he ? So I would have to say yes to some degree.
  3. #29
    Jan 2010
    Quote Originally Posted by royd2 View Post
    idk why he wanted to change the dt switch he didnt even test it but if it were bad it would not stop from defrosting would it ? it would just stop from terminating at temo right?
    It would not stop defrosting if the timer motor stopped while in defrost yes but most systems have a heater hi limit to stop a melt down form happening. Also if you fan delay/defrost termination failed in the termination mode, it would trigger the defrost solenoid taking it out of defrost mode as soon as it went in.
  4. #30
    Mar 2009
    Mid-Mo
    Quote Originally Posted by supertek65 View Post
    LMAO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    I thought you were just a straw boss. Ha.
  5. #31
    Sep 2011
    Plainfield IL
    im going to guess the unit your working on is a very old semi hermetic compressor with weak valves. Let us know what you find Roy
  6. #32
    Jan 2012
    ohio
    as it turned out we changed the defrost terminators and the contactors. i think the contactors were sticking keeping the compressor running when it should have shut off
  7. #33
    Phoenix, Arizona
    Well on some larger systems the heater won't energize till compressor shuts off. Heater relay off aux contacts on compressor contactor. Your post #13 is a good starting point to check.
  8. #34
    Phoenix, Arizona
    Guages and electric meter will tell your problem.
  9. #35
    Southeastern Pa
    Quote Originally Posted by steve36558 View Post
    I think he fixed it...
    2 Tim 3:16-17
    AOP Forum Rules:
  10. #36
    Mar 2001
    Ilwaco, Washington
    So,,,,you changed the DFT, the contacter, and the time clock,,,,,,Which part was faulty, or were all three bad??? I'd have a hard time billing a customer for parts that weren't needed, or maybe that's just me,,,,,,,,
    One way to outthink people is to make them think you think. They'll think you're not really thinking what you're trying to get them to think you think...........
  11. #37
    Southeastern Pa
    Naw, it's not just you.
    2 Tim 3:16-17
    AOP Forum Rules:
  12. #38
    up in the hizzy
    Quote Originally Posted by uniservice View Post
    I'd have a hard time billing some customers for parts that were needed
  13. #39
    Jan 2010
    X3
