    May 2002
    I can't find manufacturers that utilize a closed loop refrigeration heat tube for dehumidification units.
    someone mentioned some company in Israel doing it. Anyone know of manufacturers utilizing heat tubes w/refrigerant?
    TIA
    Va Beach Va
    May 2002
    There was supposed to be some company in Israel doing this in a ERU type unit also.....
    Va Beach Va
    Sorry not familiar with a heat tube manufacturer from Isreal.
    [Edited by hvac magician on 10-14-2006 at 07:57 AM]
    Apr 2002
    These guys are not Israelis but are pretty kosher
    http://www.engineeredair.com/Product...sp?ProductID=8
    http://www.ductstrap.com/
    Georgia
    The company I work for manufactures an indoor pool dehumidifier that also incorporates a heat pipe in a refr.-based dehumidifier to precool return air before getting to the DX coil. This drops the compressor size required to maintain humidity by about 20% over straight refr. dehumidifiers. The captured heat in the pipe is used to temper outside air used to ventilate the space. If this is the type of product you were looking for, find out more at http://www.aers.com.
    Good luck
