Results 14 to 17 of 17
    central New Jersey
    Keating griddle "shelf"
    The whole table that the griddle sits on, including the casters needs to be replaced. Their terminology is "shelf". The whole thing is collapsing. I'm sure it could be reinforced with bolts and such, but it would be easier to just get a replacement and slid the griddle onto it and be done.
    It is in a tight place and would have to be moved by professional weight lifters. Its a 60 inch wide grill...heavy.
    Ft Worth Tx
    Id have a welder look at before ordering it from Keating. There charging so much for the special order. You can always get the casters from Franklin machine or CCC. A welder might be the trick.
    My dealings with Keating have also been less than desireable.
    Good Luck!
    central New Jersey
    Keating griddle table
    I'm sure the existing table can be repaired, even without a welder. The problem is what do I do with the griddle when I take the table out from under it? The space is tight and I'm not getting a hernia
    Going to shop around for another table though.
    Ft Worth Tx
    For the big 6 footers we have a pair of magnets and use a lift. At times when you cant get a lift into place you use three or four Bubba's.
Comfortech365 Virtual Event
