Results 1 to 11 of 11
    Aug 2012
    Will painting home's walls really give me 11% decreased energy bill?
    http://www.ba-pirc.org/media/pdf/Ref...ls_DParker.pdf
    This study seems to say painting them white will do so.
    If you live in Florida and your AC energy bill is $2400 a year than that is $240 in energy savings or $20 a month.
    Obviously that's not enough of an energy savings to actually make it worth repainting your home, but if you are going to repaint anyways, why not make it white?
    Intuitively it sounds a little high. Any real world experience with this?
    Last edited by newstudent; 10-03-2012 at 10:30 PM. Reason: should of added WHITE to the subject sorry!
    Oct 2010
    If you painted the outside of your house white... Maybe.
    Des Moines, Iowa
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Further infractions may result in loss of posting privileges.
    Fort Worth, TX
    Put a white reflective roof on your house, and with ducts in the attic you will see a noticeable drop in electric usage to keep your house cool in summer. Paint all of the exterior walls white...if you have unshaded walls of your house, or large sections that face east or west, a lighter color could help reduce the intensity of heat transfer into the house in summer. As to what extent, that would require modeling to get an approximation.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Fort Worth, TX
    Rebehanish, you need to apply for pro membership and further apply for AOP privileges to post here. I'm not a moderator but I am saying this for your benefit. Your postings in this section will be deleted at some point by a mod, just so you know.
    Des Moines, Iowa
    Aug 2012
    "I'd be interested in how they come up with that one. Anyway how could you prove that 11%rate? "
    Just read the link in the original post. They did a study over several months on a mock up home.
    What I found particularly amazing is this shed already had a white roof on it and the walls were a very light tan color, and yet they still reported this improvement. FSEC is known for the quality of their building science reports, and they are not some paint manufacture trying to sell you something either.
    Fort Worth, TX
    Newstudent, my advice to rebehanish applies to you as well.
    Aug 2012
    your advice is misguided I started this thread and am not breaking any forum rules that I am aware of.
    south louisiana
    for unshaded properties,
    sun hits roof all day.
    sun hits walls one wall at a time for
    lesser hours than roof.
    white roof has better savings, walls
    lesser savings.
    in remrate we enter roof info (light reflective medium dark) and exterior
    wall info (light medium dark). I've never broken it down by changing
    wall info to see what exactly it saves to go with lighter colors.
    11% doesn't seem far off though.
    a lot would depend on wall size, orientation & exterior shading.
    but if you are re-painting..lighter is better for cooling climates.
    I'd like to repaint my house soon, well after the
    last 4 windows are repaired.
    originally I wanted a red ..18 years ago when I first moved in.
    now I'm leaning towards a cream color.
    with dual colored trim.
    if you are repainting take advantage of every money saving
    thing you can.
    taking the time to do the prep work, caulk well before paint
    & investing in quality paint. help the paint job to last longer.
    best of luck.
    Quote Originally Posted by newstudent View Post
    You are correct, your not breaking any rules.
    Of course, if you give me a couple minutes I can make a rule up so you are. LOL
