Results 14 to 14 of 14
    Rochester NY
    +1 to these
    1400 sq ft new construction in your area shouldn't need a 2.5 ton single stage A/C let alone a 3 ton 2 stage. 2 tons should kill the place.
    A basement won't add enough heating or cooling load to need a bigger A/C or furnace.
    Don't bother with a "16 SEER" A/C with the GMH. You sure won't get it. I wouldn't waste the money on the GMH. If you want comfort, got to the GMVC. Otherwise stay single stage.
    45,000 Gmvc with comm stat. 2 ton 2 stage heat pump.
    Quote Originally Posted by 54regcab View Post
    A NEW 1400sqft house shouldn't need more than 50,000BTU heat just about anywhere in the continental US. If 50K wont keep a 1400sqft new house warm the insulator/air sealer failed miserably.
    Doubt a 45 will ever see high stage.
    Energy Obese? An audit is the next step - go to, or RESNET, and find an auditor near you.
